Howdy. Came back from a 2-week vacation to find, not a real puddle, but a flat, thin spread of fuel on the garage floor. I'd had some drips before that which seemed to be a function of fuel spitting forward into the air cleaner during operation, and I got the impression that this was not abnormal.
But this was a greater volume of fuel. I noticed that I had left the fuel lever in the "on" position, and remembered that that could also sometimes allow leakage. So I turned the lever to "off" and hoped that would solve it. By the end of the day, most of the fuel had evaporated, and I figured I was fine.
Next morning, there was fuel on the floor again. I had left the tank pretty full before vacation, but checked and noticed it was way down. Hmmm. Found out just how far down when I went on an errand and the bike died at the end of the block. The tank had drained exactly to the height of the "reserve" tube. Don't know if that was significant, but that's the case.
So here's where I'm at: I pulled the tank, and there's no evidence of a leak at the tap or either end of of the fuel line—everything is is bone dry, and the fuel line is new. There IS evidence of fuel in the air cleaner—I can see the liquid shine with a flashlight—and at the bottom of the well. And I can't find any sign that it dripped again last night, when the fuel was below the "reserve" tube.
Any thoughts about what's going on and how to fix? Carb float? Has anyone ever encountered a leak that only occurs if the fuel level is ABOVE the reserve line?
Thanks for any advice.
