I have read some threads about changing the rings on my two-stroke scooter, but I don't see anything about cylinder bore prep. On every automotive and tractor engine I've rebuilt, it is necessary to remove the ridge at the top of the bore where the ring travel stops (bore wear is only below that point), bore to the next oversize unless wear is minimal, and finally hone the bore so the walls have a new cross-hatch pattern.
Is the scooter cylinder bore made of a super-hard material that doesn't require this attention (assuming that the piston hasn't seized)? If the piston and bore look good, can I really just pop in a new set of rings and gaskets?
