Hi all, something for you to muse over......
I fitted a Polini 208 kit to my TX200 (Spanish T5 with P200 engine) and ran it in correctly as stated for 350 miles.
I then decided to see how it performed top end, I was travelling at 70ish mph with approx 7k RPM when it soft siezed on me.
(I also have a SIP Speedo fitted with CHT gauge and was showing 135 celsius).
It was only a nip up and after a couple of minutes, it started and got me home.
It got me thinking though after reading online that max revs for a P200 is 6000rpm, but the T5 Speedo hits the red line at 7500rpm.
I appreciate that there are multiple factors for a soft sieze but I was wondering if a larger clutch drive gear would lower the max RPM?
Standard P200 clutch gear is 23 tooth, it's possible to get a 25 tooth.
Any thoughts on the above appreciated
