@ray8 avatar
@ray8 avatar
PO removed it.
I have all the parts except this lever.
Any sourcing help welcome!
@greasy125 avatar
@greasy125 avatar
Kajiit might have. if not I probs have a whole assembly.
hit me up on the tech line later and I'll poke around the catacombs for ya.
@ray8 avatar
@ray8 avatar
@gickspeed avatar
@gickspeed avatar
Ray8 wrote:
PO removed it.
I hate that stuff. Why can't people that don't know what they are doing just leave stuff alone. Absolutely no reason to take that off . . . Or remove auto-lube.
You just got lucky. I knew I had a pump in pieces but it turned out to be different than your pic. It's maybe LML or later PX, I dunno but you can see that it's way different. So I dug deeper into some random carb stuff I inherited from a friend. Eureka, I found one that matches! But it doesn't look like the arm comes off without wrecking stuff, so you need the whole cover, right? PM me your address.
The one on the right is nothing like yours
Even more different inside
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Voodoo working dat Vespa Voodoo!!
@ray8 avatar
@ray8 avatar
The one on the left is absolutely it.
I was going to call you Saint Voodoo but that doesn't come off right
DM sent. Thanks!!!
@ray8 avatar
@ray8 avatar
Saint Voodoooo!!!
Some pics:
Lever is held in place via a cotter pin. Washer or o-ring? Idk.
What I got from the seller in a bag with everything else needed, including the original airbox.
Woops... I'm going to try to modify it and add a plastic tank, or get an aftermarket tank(?).
@gickspeed avatar
@gickspeed avatar
i have what i believe is a good tank.
@ray8 avatar
@ray8 avatar
Got the tank from Mr Gick, so now all I need.
Awesome.
For posterity, here is how to assemble the earlier autolube's:
(main takeaway -- don't use a fiber gasket on these)
&t=1365s
[ Time: 0.0108s ][ Queries: 4 (0.0043s) ][ live ][ 339 ][ ThingOne ]
