@vsteve49 avatar
2005 PX 150, 2008 LX 150 2022 Sei Giorni., 2016 Sprint 3vie
@vsteve49 avatar
I am replacing the carburetor on my 1964 150 vbb. Both carburetors are Spaco SI 24/24e . The guy who sold me the bike said that it had been kitted, hence the bigger carb for the 150. My problem is when I pulled the old carburetor off, the air box gasket is different from the new air box gasket that SW sent me. So my question is which gasket should I use. I have pictures. The first pic is of the air box. The second pic of the two gaskets. Left old, right new. The rest are of the gaskets on the carburetor old gasket two holes, new gasket three holes. The old gasket covers the hole on the bottom of the carburetor, new gasket allows the hole to be seen. All comments welcomed, thanks.
Air box
Air box
Gaskets
Gaskets
Old gasket covers hole in carburetor
New gasket allows hole in carburetor to be seen
Bottom of carburetor
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
You've got an auto lube carb. There's no passage in the air box for oil. I'd use the gasket but put a smidge of RTV into the auto lube hole on the carb - only needed though if that hole will be able to suck air, which depends on the mating surface of the box. Drop that gasket onto the box. If the hole is on a machined surface, no RTV required.
[ Time: 0.0091s ][ Queries: 4 (0.0023s) ][ live ][ 313 ][ ThingOne ]
