Hi,
I need a little help here.
Most importantly, I need to know if my reasoning works.
I have a Vespa Primavera 4T3V from 2018.
I've slightly upgraded it with a Multivar and used the 6.1g weights that came with it.
I've replaced the CDI with an unrestricted Malossi CDI.
I thought it was running quite well until I switched to a Malossi MHR X K drive belt.
The belt is 765mm long instead of the original Piaggio belt, which is 756mm (I believe).
Here's my theory (bear with me, this might get messy).
Longer belt = it goes higher up in the variator, allowing for a higher top speed.
…but I feel like the acceleration got worse and that the Vespa became weaker after I made the switch… Also, the top speed was about 55km/h (34 mph).
Shorter original belt = doesn't go as high up in the variator, making it a bit slower, but I felt like it was quicker, stronger and faster…
So here's my question: does this seem logical?
Should I go down to 5.5g weights and keep the longer drive belt to improve acceleration, revs, and power at the start?
Or should I keep the 6.1g weights and switch back to the shorter original belt?
My ULTIMATE goal are that I would like to be able to reach 65km/h (40 mph) without doing anything more than adjusting the belt and variator.
I want it to be strong at the start, and I don't mind if it takes its time to reach top speed.
Is this even possible?
I need to take it to the workshop for servicing soon, and I would like to have the right parts with me.
Unfortunately, I don't have a place to work on it myself, so the workshop is a must.
Sadly, this doesn't leave much room for experimentation…
