My buddy has a 74 bajaj vbb that I've been trying to help him keep running. It'll fire up and run for about 5 minutes and then just die with no amount of kicking or bump starting gets it going again. The next day it'll start up again for another 5 minutes and die. There's spark and I've cleaned the carb completely twice and switched out the needle jet and float thinking it was flooding out. It doesn't rev up when it dies like it's running out of gas, just dies. The plug looks good to me. Wet but not black
Johnny Two Tone
Posts: 8836 Location: San Diego, CA |
Blocked tank vent is a good idea for sure. I'll take the fuel tap out and clean it out.
If it was a coil wouldn't it not have spark when I check for spark after it dies? sdjohn wrote: Blocked tank vent? Bad coil or stator coil that dies with heat? |
Johnny Two Tone
dsmith181 wrote: Blocked tank vent is a good idea for sure. I'll take the fuel tap out and clean it out. If it was a coil wouldn't it not have spark when I check for spark after it dies? On the coil maybe but maybe it just gets weak. |
Posts: 2149 Location: Philadelphia |
sdjohn wrote: You can just run with cap open, it's not about the tap itself. On the coil maybe but maybe it just gets weak.
Positive
Did you check that fuel goes at normal speed through the fuel hose ? It could be a blockage from the tap due to dust, residues…
jape wrote: Mine did similar before I replaced the coil. It wasn't 5 minutes… it was more like 10-15. I have spark for the first 5 kicks and then nothing... going to switch it out to one I have on another bike that runs |
I switched out the cdi and external coil that I know are good and still no spark.
I think it's time to move on to the stator? |
Johnny Two Tone
sdjohn wrote: (Cue negative remarks about Bajaj electronic ignitions from the crowd)…. |
Johnny Two Tone
from what I know, the bajaj ones can work but often have electrical faults that keep them sidelined. usually a bunch of people chime in the moment they see it's a bajaj system and tell you to ditch it. I have no experience with them yet, but it's just a pattern I've observed.
people in the know will be along soon. |
So I replaced the stater and flywheel and it fired right up. It must have been the ignition coil on the stator.
This is the set up I have on there now. Thanks |
Should I be concerned that the flywheel doesn't have cooling fins? I've never seen one without them.
Lucky
Posts: 10352 Location: Nashville 153 Days Since Last Explosion |
Lucky
sdjohn wrote: (Cue negative remarks about Bajaj electronic ignitions from the crowd)…. dsmith181 wrote: Should I be concerned that the flywheel doesn't have cooling fins? I've never seen one without them.
Positive
1961 VS5T, 1981 P200E, Rigid Frame Chopper, 2001 Harley FXDXT
Posts: 1282 Location: Ventura, CA |
dsmith181 wrote: This one? |
Lucky
Lucky
SIP now make the Vape for the small cone crank, which is money well spent if you insist on running an OG crank.
chandlerman wrote: As OP has now demonstrated, we make those negative remarks for a reason. There should be a (plastic) cover that bolts onto the flywheel. Check you old flywheel and you can probably remove it off that and re-install it onto your new one. |
Lucky
Lucky
