Vespa Sprint 1966 PX200
I will use my 60mm Bgm crank with a original px200 cylinder and a gs piston. Is it a 1,5 cylinder base gasket and no head gasket that is needed?
And another question, can a Polini 221 kit cylinder be used with a 57mm crank or does it have to be milled down?
@steely_dan avatar
Too much stuff
@steely_dan avatar
Too much stuff
As far as the 60mm crank is concerned, you can run this crank with zero base gaskets and usually no head gasket. you just have to check for squish. This was a common modification back in the day. i suggest keeping your port timings low and IF you need a larger squish run a head gasket.
You can live inside the factory squish of these bikes from the factory.
[ Time: 0.0085s ][ Queries: 3 (0.0024s) ][ live ][ 339 ][ ThingOne ]
