My '00 Typhoon 125 2t sat for at least six years. I got it running this summer (including cleaning the carb internals which were in surprisingly good shape). The compression felt low to my thumb test, so a new cylinder/piston/ring set is on order but has not arrived yet.
The problem persists of severe blue/white exhaust smoke only when hot.
It starts immediately when cold, and idles normally. But after driving for a few minutes, when the throttle is opened wide, the clouds of smoke are impressive. It also seems to have a vibration at lower speeds/engine RPM which is not there at higher RPM. IIRC this can be a sign of excessive richness?
I did check the automatic choke for 35 ohms resistance, and getting 12 volts with the engine running. Could the choke still not be functioning and closing the enrichment passage? Or the worn rings causing smoking only when hot? Or both...
I am aware that I can take the choke off and apply 12V to see if the pin extends. But I anticipate that the rusty-looking screws may be hard to remove even if I take the carb off... just looking for experienced diagnostic tips
⚠️ Last edited by DrCharles on UTC; edited 1 time
