My scooter is a 2023 Vespa GTV 300.
When doing top speed run, around speed 132km/h (82mph), the CEL was blinking, but the scooter runs fine without any hesitation, just the CEL was blinking like 1hz frequency.
When I slow down to 120km/h or lower, CEL stopped blinking. (also not light on, just like nothing happened).
The only archived code is P0301 which says engine misfired detected. But it does not imply that happened during top speed run, simply means it happened. And if I turned the scooter off completely and restart it. No code is stored and can be read out.
It does not look like a rev limiter kick in, scooter runs fine and smooth when CEL blinking.
I had my ECU top speed limiter raised to 200km/h, the RPM limiter raised to 9900rpm.
I run a 13 inch wheels front and rear and the Speedo is 100% match with GPS Reading, 132km/h on the clock when 132km/h on the GPS.
