2008 Piaggio BV 250
2008 Piaggio BV 250
My BV 250 2008 when idling or at constant speed has a constant clicking noise. Stops or minimizes when accelerating any suggestion on cause?
a video of it would help. also since it happens at idle you should be able to locate where it is coming from.
Rollers rattling?
2008 Piaggio BV 250
2008 Piaggio BV 250
Possible. I was wondering if a sticky valve.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Mileage on the scoot? Frequency of clicking matches engine speed? Recent belt service?
2008 Piaggio BV 250
2008 Piaggio BV 250
Thanks for responding. 6k miles, ticking only at steady speed, goes away or minimized with any slight acceleration, original belt never serviced.
@bvbob avatar
@bvbob avatar
It's most likely the rollers. My BV200 has always made a noise as you described. It's got almost 38,000 miles. It's just an inherent sound of the scooter.
Bob
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
With that low of mileage, not likely anything wrong with the motor unless it was run low on oil. Could be a valve but it wouldn't be sticking, would be excessive lash. Could be rollers or something else in the transmission.
If you are DIY, flip of a coin for which to try first. 6k is low mileage for a belt change but it is 15 years old. Take a good look while you're in there for anything loose or rubbing, swap out the rollers and belt and you might fix it. Valve adjustment is a greater degree of difficulty, mostly because of crap access.
If you're taking it to a wrench, they might have a better opinion on what it might be.
2008 Piaggio BV 250
2008 Piaggio BV 250
Thanks. I'll get in to check rollers and belt. I need to check the vacuum hoses as well. Just a pain to pull all the plastic off for access. Thanks again.
[ Time: 0.0133s ][ Queries: 3 (0.0015s) ][ live ][ 339 ][ ThingOne ]
