LX150
LX150
How does one check the oil with the dip stick?
On the honda scooters I worked on, you do NOT screw in the dip stick when checking the oil level.
I was not able to find information in the owners manual.
Do you check the oil level by screwing in, or not screwing in the dip stick?
@mopedlar avatar
2001 GTS Super (white), 2021 GTS Super (yellow), 1976 Bianchi Snark moped, 1980 General 5 Star moped
@mopedlar avatar
I was always told that the dipstick needs to be screwed in and then unscrewed to read the level. Every Vespa I've ever owned was the same.
deleted
⚠️ Last edited by Tierney on UTC; edited 1 time
Agreed, you need to screw it all the way in to check the oil level. Look at the WIKI section under the Modern Vespa banner at the top of this page. Lots of helpful info there.
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
That is correct.
It is not limited to all Vespa's, it applies for all Piaggio scooters.
[ Time: 0.0092s ][ Queries: 3 (0.0032s) ][ live ][ 313 ][ ThingOne ]
