Old douglas ..smallie with polini 115..super with nasco 177
Due to rust repairs there are no holes for the chrome strips.I have a new set of correct screws via SIP.How do I proceed?
VNB VSC VMA VSX - o9c vbc vmb
I did this on one side of my VNB.
*Make sure you shape/bend the rails to match the tunnel before you do anything
*Once shaped. Mark one of the interior holes with the rail taped in place.
* use a punch to center tap a divet for a small drill bit. Remove rail and drill the first hole. This is by far the most squirlly part. Make sure the drill bit is sharp and that you get a good bite so the drill doesn't walk.
* Place the rail back on and secure the one drilled hole with a small screw or pin. Mark and punch the next hole.
*Wet, lather, rinse, repeat.
[ Time: 0.0090s ][ Queries: 3 (0.0030s) ][ live ][ 313 ][ ThingOne ]
