180ss
180ss
Hi there, just wondering what's the easies way (and which cleaning products too) to clean the engine case bolts? Mine are quite dirty/greasy especially in the threads? Gasoline? Brake cleaner? Any Aluminum cleaners?
Fab
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
I like kerosene.
@moto64 avatar
@moto64 avatar
I , too, use kerosene, a stiff brush and a blast of water. Leaves it so clean it will rust.
180ss
180ss
I have a small container of varsol, would that be good, or too harsh? These bolts are the black ones. I wonder what they are made of, they look kinda powder coated?
Fab
@colinbelgium avatar
VBA1T/Px200 iris/VNB6T
I put them in a plastic jar with diesel (the lid has a hole for Vapor's), put the jar into the ultrasonic cleaner (full of water) for 10/15 minutes, wipe the residues and dry them.
Then I like to soak them into mineral oil, take them and simply wipe. That gives a nice finish and a layer of protection against rust.
180ss
180ss
Colon, unfortunately, I don't have an ultrasonic cleaner, this is why i was asking about simple, chemicals i can use. Would soaking in 2 stroke gas be good too?
The ultrasonic just speeds the process, especially the fine brushing into the threads.
2 stroke gas should work, maybe not as good as diesel, it is greasy and has solvents. 2 stroke gas has also oil so should work better than dish soap and a sponge
180ss
180ss
Or would just plain old gas, do the job better?
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
More volatile, fumes… If you absolutely must use gasoline do it outside.
Fab
Varsol is a thinner, don't use that, it will degrease but it is extremely volatile and fumes are very strong and toxic for lungs
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
The black coating is from heating the hardware red hot and plunging into seed oil
@bajarob avatar
@bajarob avatar
I use the parts cleaner at my work. Stoddard solvent with a stiff plastic brush followed by a coat of oil then wiped off.
[ Time: 0.0091s ][ Queries: 3 (0.0016s) ][ live ][ 339 ][ ThingOne ]
