1953 vespa faro basso VM1T
hello everyone,im after some help locating the drain point on my 53
vm1t,i can only seem to find the oilo bolt ,is this the filling point or te drain.
thank you
gazmph
vespa faro basso vm1t
@daleb avatar
'55 VL1
@daleb avatar
'55 VL1
Disregard my earlier reply, I was wrong. After I posted it, I realized that since I last worked on the Vespa I've changed oil in two or three other engines that DO only have a single drain/fill point, and I was wrong. There is a drain bolt at the low point of the gearbox, just behind the center below the kickstart lever.
@gickspeed avatar
@gickspeed avatar
if it's early enough, you only have one. my early v33's only have 1.
[ Time: 0.0089s ][ Queries: 4 (0.0023s) ][ live ][ 339 ][ ThingOne ]
