Here's the situation: my P2 engine had been running quite nicely for a while; only issue had been some slight bogging when cold, which routinely cleared up after a quarter mile. No biggie. But the bogging started lasting longer, up to the point when I was headed out for a countryside ride and had to return home after about 15 miles because in the low to mid rpm range the engine seemed to want to stall. I only managed to get the engine starting again by messing with the idle screw.
I checked the ignition: pick up and LT coil gave good readings. Switched carbs: same issue.
I then decided to try a leak down test to see if there was some transfer of engine oil into the combustion chamber, and after checking that the oil seals, the cylinder and its head, and the casing were airtight, I found this:
The stud whose threads the air is leaking from is one of the 4 surrounding the crankshaft: the top right once the rotor is removed. That stud is separated from the crank housing with a paper gasket and liquid sealant (reinzosil). The stud itself has no play, and was glued with loctite 271. There should be no way in hell that air could go past the torqued-down cases, the gasket + liquid gasket, and the loctited stud, but here we are. Any ideas how this is
even possible?
I ended up filling the remaining empty space at the butt of the stud with JB Weld, and it no longer leaks from that particular area. But there's still a leak somewhere that takes the pressure from 300 to 260 mmHg in 10 minutes.
