Hi,
2 months ago I bought a Vespa GTV 250 from 2008.
The motorcycle had been stopped for some time and had not been maintained.
The motorcycle has 45,000 km ( 27000 miles)
Apparently the exterior and the sheet metal are very good.
It is preserved in good condition
Once in my garage I changed the oil engine (Motul), oil filter, Malossi red air filter, hub cube oil, variator filter, circuit cleaning and new coolant, new brake liquid ( dot4), new tires ( were hard and glassy) , new burned out bulbs...change old fuel...
It had a motor error fault and have high voltage peaks in the battery that were solved by replacing the voltage regulator.
I did a basic maintenance because i dont know previous maintenance history.
The bike starts and runs.
It has a strange sound, mentioned in another post, which may be from the transmission. No bright lights on dashboard .
Strange Noise Vespa GTV250 (2008)
On a flat surface max speed is about 110 km/h (68 mph), on a Hill the máximum speed is about 100 km/h( 62 mph). My weight is 90 KGS
I think it is low speed for a vespa gtv 250. My old vespa p200 2 T (1980) does those speeds.
What do I need to do to have more maximum speed?
Chage belt transmisión?
Which belt ?
Vespa original?malossi, others ?
Change variator and rollers? Original? Malossi multivar 2000? Polini 9 rollers?
Cluntch need something??
Its necesary update ecu software?
What would you do to increase speed?
Thanks for all!!
