I had some rattling and randomly occurring noises coming from the right side of the scooter. Mostly when leaning it over in a curve or hitting bumps in the road.
As you can see, the flywheel fan had completely broken apart and the pieces were scattered in the space behind the shroud as well as lodged in between the cylinder head and the air guide 'housing' around the head fins.
I found a used fan on eBay and AF1Racing had the shroud assembly. Both are on their way.
My question: Do I need to look deeper than simply assuming material failure? The fan is not something anyone seems to stock here in the US and so I assume it is a rather rare occurrence. Which would suggest simply putting it back together and moving on. Other thoughts? Thanks.
PS: FYI, I did not ride it more than a few minutes after the noise started so I hope to not yet have caused any engine damage due to lack of air flowing around the head.
