@black1999 avatar
GTS300
@black1999 avatar
GTS300
Hi all
Recently my 2011 GTS developed a stange symptom.
When I start the bike in the morning, all seems good, but when rolling the throttle, it will stall and die.
It can move forward for a while but stall when moving.
The most strange part is, after the engine temp went up to maybe 1/3 of the meter, all is good.
I have a passenger with me, if no passenger the situation seems be better, this needs more test.
(Update: when I ride alone, the situation is very minor or none)
First I thought it might be water in the fuel, but after some test I think not.
I also suspect maybe the weight of riders cause some tube to crack open, after check I noticed there is crack on my evap tube, but after I blocked the tube it's still the same.
So far I didn't see any damage or wear inside the bike.
Does anyone ever have similar problem? I don't know where to start looking now.
Thanks.
⚠️ Last edited by black1999 on UTC; edited 1 time
@wbdvt avatar
@wbdvt avatar
How many miles on it? Sounds like valves may need to be adjusted
@black1999 avatar
GTS300
@black1999 avatar
GTS300
It's about 60,000 KM now.
@wbdvt avatar
@wbdvt avatar
I would check the valve clearances
@toalmar avatar
@toalmar avatar
If it has something to do with the valve clearance I think it's because the clearance is to big, then you should heard the ticking, or?
There is some tip in the workshop manual, please see attached picture from it
This is a classic symptom of valve clearances being too tight - though it's a much more common problem on the older Leader engines, as noted in the Piaggio tech bulletins. However, ensure the idle bypass passage is clean first...
At 60,000km checking the clearances is due anyway, so might as well do it.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Thanks for all the reply.
It kinda happend overnight, not gradually, also I am not hearing valve rocker ticking sound... but I will try to check it.
It's so hard to reach valves on a GTS compare to all bikes I rode before.
Compared to many scooters out there, the valves are fairly easy to get to once you set it up right. Try working on a Honda PCX - it will take over an hour just to remove panels and such just to get to the valve cover.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Update:
Found damage on HT coil, replaced the coil, didn't solve the problem.
This morning I notice when I turn the key, I didn't hear the sound from fuel pump.
But the scooter can start and run, how?
My question is, could a fuel pump partially fail? Maybe it's a fuse or a relay?
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Update:
After some research, I sand the connectors of pump relay, switch relay positions.
Now the pump primes, and this morning I start the bike and ride with no issue.
Maybe the problem is gone, just leave a record for someone in the future to dig, too many posts that have no ending.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Update: the fight still go on but I see the light.
Things didn't go well after I cleaned relays, the problem persist.
I went to a dealer for electronic system check, hooked a computer and everything shows fine.
The dealer advised me to replace O2 sensor, and still no good.
A friend suggest it's pressure valve on fuel pump, because after stall, it will be hard to start for a while.
I bought a fuel pressure gauge and tested pump:
https://www.youtube.com/shorts/8_BXR1PRDFo
I imidiatly knew it's the problem.
Now I need to get a new set of fuel pump.
@abner_bjorn avatar
@abner_bjorn avatar
You can buy the pump only for around $20. You don't need to buy the whole assembly. Good luck with the repair. While you have the bike jacked up, and the engine dropped to get to the tank, this is the easiest a valve adjustment will ever be unless you pull the motor.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
As far as I know, the check valve is inseparable, only the motor is.
Yes I indend to do the valve adjust when remove the tank, I really want to know how much the clearance increased.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Pump replaced, tested and everything is normal now.
Valve clearance is still in range, maybe the previous owner had it adjusted.
@berto avatar
2018 Liberty 150
@berto avatar
2018 Liberty 150
Nice work! Clap emoticon
[ Time: 0.0129s ][ Queries: 4 (0.0058s) ][ live ][ 343 ][ ThingOne ]
