Vespa 2022 Primavera Sport 150 w/ Full LED Dashboard
Flashers indicator on LED Dashboard not working - as well as the actual flashers are also not working. Fuse is good. Bulbs are good.
*CHROME* HORN/TURN/HEADLIGHT LEFT (LH) TURN SIGNAL SWITCH ASSEMBLY was inspected and turn switch hit with WD-40. High beam and horn, which are part of the assembly, are both working. It's just the turn left and right switch is not engaging (as seen by not lighting up on the dashboard) as well as all four flasher bulbs which are not working. For this model, it is my understanding that you must replace the whole assembly I referred to above.
Any ideas?
