CrazyCarl wrote:
Welcome to MV! That's a great looking scoot! There's tons of great info on the website and Vespa ownership can have a profoundly positive impact on your life. Feel free to search or ask any questions. Check the WIKI section at the top of the main page. That vintage of LX has an excellent 150cc motor and with good maintenance will last a long time.
Given that it has such low mileage for an older scoot, there are some items you should address. Most all maintenance can be DIY with common tools and a couple of specialty tools.
Tires, belts, and hoses age with time as well as mileage. The tires are likely original and will be way past their expiration date; the rubber hardens with age and your traction will be greatly diminished. All the hoses are pretty easy to access once the underseat bucket (aka pet carrier) is removed. Check them carefully and replace any that look to have cracks or dry rot.
The drive belt is an item that sees significant stress and if it has any dry rot, it will snap while riding; I had a 7 year old belt with only 1000 miles on it snap a few years back. You'll be stranded and left with an ugly mess inside the transmission cover. This is where you'll need specialty tools called a variator holder and a clutch holder. Not very expensive and easy to order online. Some have even made their own.
Brake fluid, engine oil, and gear oil should also be changed if it hasn't already been done.
Take care of these items and you'll be able to enjoy that scoot for a long time.
CrazyCarl, thank you- this is exactly why I joined this forum..
Just as additional info, before Vera came home, I had both tires replaced, engine and transmission oil replaced, drive belt replaced and all electrics gone through (other than the clock battery that's dead - I'll get that when I go LED and lose the US turn signals)
I personally inspected the fuel pipes as you recommend, and ran the bike and squirted the ole carb cleaner under the pet seat.....she didn't even murmur....
I cleaned the air filter this morning, and I'll change the brake fluid here in the near future.
