Fly 150
Fly 150
Hello, new to piaggio, but not new to tuning scooters or engines in general.
Long story short I came across a piaggio fly 150 4t with the leader engine. The carb was missing and had a spare pe28 carb laying around.
I saw someone post their stage2 mods on the leader engine and figured it would be a simple install but find the bottom of the carb hitting the block.
Is there a spacer that's made to rise the spigot manifold up a few mm? Or did other users who went this route find another solution to the space issue I'm currently having?
Fly 150
Fly 150
Well. Guess not many modders here. So order an aluminum 6mm thick in aluminum. Will do make a custom spacer and see how it goes.
I'm not worried about upper range performance being effected for the engine with a slightly taller intake length. Factory is short enough that 6mm won't matter.
@az_slynch avatar
@az_slynch avatar
This is the thread you seek:
ET4-LX 150 Leader engine:Stage 2 tuning
I have an '07 LX150, but it's so far on the back burner that it's on someone's stove in another state. Waiting on a tuner to finish getting the replacement larger exhaust valve finished (cut down and reground).
Fly 150
Fly 150
Yeah that was the post I came across. I saw he fit the pe with no issue but I can't seem to get mine to fit at all
Fly 150
Fly 150
Well I missed something in that post and it was to cut the cooling shroud and voila! She's running on the pe28 now I just need to install the single throttle cable and finally get to enjoy riding the fly 150
Fly 150
Fly 150
Crying or Very sad emoticon well scratch that. My throttle cable won't fit the piaggio. So I ordered a new throttle assembly that will accept it along with some new throttle grips. Should be here tomorrow.
@az_slynch avatar
@az_slynch avatar
Glad you're making headway. I need to get back to mine. At this point, I may just ship some cams out for regrind and reuse the stock head.
Fly 150
Fly 150
So quick update. The carb needed rejetting as it did not like to idle on a 38 pilot. But a 40 solved it at 2 turns out on the pilot jet.
The main jet it came with was a 110, and it did not like that number at all. Put a 125 main and every bit of a bog that would occur disappeared.
Fly 150
Fly 150
Id like to have more info on this as I'm debating on throwing a 200cc liberty cylinder then having a machine shop cut down on the head to raise compression to 11:1 like the malossi. Or just going malossi 190.
One thing I am trying to find info on, is a cdi that's compatible with other piaggio or vespa models that can be swapped in. As it does seem there is more power to be made from a few degrees of timing.
I did also make a custom exhaust for my fly making a 1 inch exhaust come out to some cheapo muffler you can find on Amazon, but the fun with it is I can change to another muffler style that better fits the zips appearance it definitely feels like it has more oomph than it originally did. And should draggy test it to see it's current 1/8 time.
@veloce_vulture avatar
1957 NSU Prima III
1957 NSU Prima III
I'd suggest using a translator for the Asian markets forums, all bets are off with them. Needs Must! <~ Copywritten
Just for ideas and maybe more. Good luck!
Fly 150
Fly 150
Any leads for these forums? I'd give em a look over
1957 NSU Prima III
1957 NSU Prima III
I'll put it on my to do lisp, take some pictures of the technical decals on the bike, so I can code up for the translation. Any information you can find about it.
I won't start from scratch, zero point energy is a scam.
Fly 150
Fly 150
I seem to have a piaggio code going on. 2 blinks then solid. Right after I removed the evap system. As well so this may be an issue Crying or Very sad emoticon
Fly 150
Fly 150
Definitely appreciate it 😁
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
On my S150 project, I tried both 3 degree offset woodruff key and GT200 CDI from Malossi. CDI was better, right at the edge of detonation with high compression Malossi cylinder. IIRC you could slot the holes in the stator as well.
1957 NSU Prima III
1957 NSU Prima III
So what are we trying to do?
I'm lost.
https://www.extrememotorsales.com/haynes-repair-manual-scooters-50cc-250cc-chinese-clone-clone-clone-.html
It says Chinese but has Italian in the description
Fly 150
Fly 150
Any links for the offset keys? It's worth a shot. And I can also do the malossi cdi for the engine to try to get some extra take off and midrange.
Fly 150
Fly 150
I'm lost.
Overall trying to make this a potent 4t. Atleast try to get it to 11.5 (or 10s if possible)in the 1/8 mile to compete with my 70cc 2 stroke scooters. I like building reliable and fast engines for my scooters 😀
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Looks like it wasn't Malossi, Top Performances is the brand.
https://www.racingplanetusa.com/aprilia-vespa-scooter-racing-parts-woodruff-upgrade-performances-crankshaft-aprilia-derbi-italjet-piaggio-vespa-scooters-p-207411-1.html
Key just bumps static timing by 3 degrees, moves whole curve. CDI changes curve profile, I think that's why it felt better. Application is GT200 but worked OK on the 150. Just had to jet a little fat, if I dropped the needle one notch felt like it wanted to ping.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
And if you haven't figured it out yet, pod filter or gutted airbox is going to give the best bang for the buck. Of all the mods I did: big bore, cam, CDI, carb, exhaust, gutting the airbox made the biggest difference.
Fly 150
Fly 150
Running a velocity stack for the airbox on it.
So the 200cc malossi cdi can be found easily? What timing advancs did that cdi provide? And can it bypass the immobilizer? I only have the service key and it's quite picky and causing issuez.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Flyrider wrote:
So the 200cc malossi cdi can be found easily? What timing advance did that cdi provide? And can it bypass the immobilizer?
Eliminates immobilizer. Info on advance curve in the tuning thread you referenced.
https://scooterpartsco.com/gt-200-electrical-c-3637_3641_3759/malossi-cdi-for-vespa-gt-200-other-piaggio-lc-leader-p-820.html
Fly 150
Fly 150
Gonna snag this. Charging my draggy and waiting for temps to rise a bit today to do some runs to see how the stock engine and timing works so far in the 150 engine 😀.
Also gonna knock out an oil change today and find a new valve cover gasket as I have a very small leak.
[ Time: 0.0266s ][ Queries: 3 (0.0159s) ][ live ][ 343 ][ ThingOne ]
