2023 GTS 300 / 2009 S 150 / 1980 P200 w/Sidecar /1979 P200
I am installing a cosa clutch in a '79 P200e. I have the old one out and the Cosa installed with the cosa nut and wavy washer but can't find a torque value for the nut. Also is there a torque value for the wheel?
Appreciate any help!
@chandlerman avatar
Innovator
402 Days Since Last Explosion
Innovator
@chandlerman avatar
Clutch center nut is 35 ft-lbs. Some folks like to put a little loc-tite on the non-castle nuts. I usually intend to, but then don't. Razz emoticon
As to "the wheel," if you mean the rear hub nut, it's 60 ft-lbs. If you mean some other wheel nut, you need to get more specific.
Thank you! I did mean the hub nut. Now I can put this back together and see if it works and maybe is easier on my arthritic thumbs!
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Sweet!
Don't forget the cotter pin on that rear hub!
Roger that! Back together and working for the most part. shifted from neutral to 1st drove around the block then to 2nd, then back to 1st but when I stopped it would not go into neutral. I think I need to adjust the cable
[ Time: 0.0116s ][ Queries: 3 (0.0051s) ][ live ][ 343 ][ ThingOne ]
