GTS 250ie 2006
GTS 250ie 2006
Hello all, I was going to reply to an existing post but it told me it was 10 years old so I thought I'd do a new one of my own. Hope this is ok.
I have a GTS 250ie 2016 vintage, I've not ran the steed for a good few months and today I went to start it and all I got was it turning over but not firing, I noticed I didn't hear the pump prime on turning the key.
I've had a look round, proved I have 12v appear on the pump plug connection on the loom on turning the key, so have concluded my pump had give up the ghost.
The tank was run low so perhaps I have sealed its fate 😂
Before I splash out on a new pump ( I'm fairly sure it's the original pump) I thought I'd ask for your opinion. Scoot has 16k on it now.
Any opinion would be most welcome. 👍
@abner_bjorn avatar
@abner_bjorn avatar
I think you know the answer to your question, I'll pitch in vote #2 for the fuel pump. Have a read through these: GTS 250 Fuel Pump Replacement
Replacing Fuel pump Vespa GTS
Welcome to Modern Vespa!
Double check with a dealer with your VIN as you may be eligible for a free replacement under recall.
GTS 250ie 2006
GTS 250ie 2006
Thanks all, I'll pop by a dealership with my VIN number and ask the question. That would be a result if so.
@wbdvt avatar
@wbdvt avatar
You can do that online
GTS 250ie 2006
GTS 250ie 2006
Ok even better, dealer site or Piaggio ?
MP3 500 HPE 2019
MP3 500 HPE 2019
https://www.vespa.com/gb_EN/recall-campaign/
HPE Fuel Pump Failure
GTS 250ie 2006
GTS 250ie 2006
Well that's a result it falls into the recall. Thank you very much all for the info. 👍
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I am 2.5 into ownership, but the first year I had to get TWO fuel pumps which means I had a total of 3 (third time is a charm) in my bike.....first one failed at 600 miles.......second one failed at around 6000 miles......I am now at 12,000 miles and have not have had any other issues.......
@berto avatar
2018 Liberty 150
@berto avatar
2018 Liberty 150
It sounds like you're due for another fuel pump failure right about now?
[ Time: 0.0121s ][ Queries: 3 (0.0046s) ][ live ][ 343 ][ ThingOne ]
