Let me explain, I got this widebody book (kinda expensive, could've been done better, bigger pics less ads, etc)
⚠️ Last edited by dirtyDAVE on UTC; edited 1 time
VB1, VBB, VNA, VN1T, VN2T, VSX, P200, VB1T, Li150 S2,Li125 S3 Riverside
Posts: 159 Location: So Cal |
Then I bought this NEW exhaust and seller and I thought it was for one of my Allstates as can be seen in this ALLSTATE book
And all of my engines are VNA2M. and the cylinders are all the same. Like as described in the Widebody book by Sticky. Which doesn't cover Allstates or earlier 2 port cylinders that have the Intake and Exhaust right next to each other.
The book doesn't cover the earlier 2 port. Any ideas when the change was made. I am thinking 53. Sticky says all 2 ports can be identified by the exhaust coming out the bottom with the curve in the exhaust, but this can't be true.
The new exhaust fits this kind of Cylinder which is from the Earlier Allstate book. Notice the ports are next to each other.
Posts: 793 Location: Finland |
dirtyDAVE wrote: Sticky says all 2 ports can be identified by the exhaust coming out the bottom with the curve in the exhaust, but this can't be true. |
Posts: 1209 Location: Lakes Region of Maine |
This is real easy- you have bought the wrong parts manual for your bike. The tri-fives are very different from the 100-105 series.
Sticky is 100% correct in respect to the exhaust existing on the bottom for 2-port engines and from the side for 1-port engines. There are also a host of other differences as well, and to the folks that have this knowledge, easy to identify by just looking at the outside of an engine. |
garncarz wrote: Know how to weld and have an angle grinder? |
GickSpeed wrote: This is real easy- you have bought the wrong parts manual for your bike. The tri-fives are very different from the 100-105 series. Sticky is 100% correct in respect to the exhaust existing on the bottom for 2-port engines and from the side for 1-port engines. There are also a host of other differences as well, and to the folks that have this knowledge, easy to identify by just looking at the outside of an engine. |
GickSpeed wrote: Sticky is 100% correct in respect to the exhaust existing on the bottom for 2-port engines and from the side for 1-port engines. There are also a host of other differences as well, and to the folks that have this knowledge, easy to identify by just looking at the outside of an engine. |
dirtyDAVE wrote: And all of my engines are VNA2M. and the cylinders are all the same. Like as described in the Widebody book by Sticky. Which doesn't cover Allstates or earlier 2 port cylinders that have the Intake and Exhaust right next to each other. ⚠️ Last edited by GickSpeed on UTC; edited 1 time
Posts: 5433 Location: Veria, Greece |
Posts: 10128 Location: seattle/athens |
So you are looking for another one like your original, and you have THREE motors to equip? I think I have one like that i could let go fairly cheep...
Sorry for fuzzy pic, phone is down and it was taken w/ my cheep tablet cam.
V oodoo wrote: So you are looking for another one like your original, and you have THREE motors to equip? I think I have one like that i could let go fairly cheep... |
SaFiS wrote: Why not return it and buy the correct one?? |
vma1racer wrote: What's wrong with the original exhaust? |
