gs 160, sprint v, vn2t, p150x, primavera
Hi all,
I have a GS160 fitted with a P-series Malossi 210 lump.
My original engine is from a P200E but the casings are unfortunately damaged.
I have a spare PX200 casing set but the rear axle is damaged.
Can I fit the axle from the P200E axle into the PX200 casing?
And if so, what other items do I need to move across or change?
Any help will be appreciated.
Thanks, Neil
@bajarob avatar
@bajarob avatar
You more than likely have a weep hole on your PX cases for an internal oil seal. If so you will need a late model axle. Both axles will fit but the early style can only use the external oil seal and your case would leak oil out the weep hole. If the weep hole isn't present, the earlier axle will work.
Thanks.
The new casings do have a weep hole.
If I sealed the hole and changed the outer seal and hub to match the shaft, will the bearing line up with the old shaft?
And would I need to change the gear selector to the old one too due to the different selector rod?
[ Time: 0.0082s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
