@richwa avatar
Looking at getting a 2024 MP3 500
@richwa avatar
Hi,
I'm looking at getting a 2024 or 2025 MP3. There are very few available in the Pacific Northwest of the USA. I've got an appointment to go test drive one that about 300 miles from me in November.
My plan is to ride all winter so there'll be lots of night driving, including unlit two lane roads with forest on either side. My primary transport was a motorcycle; I used to upgrade the headlights. I haven't seen discussions on the headlights on the new MP3's which can be either good or bad sign. I'd appreciate hearing about experiences driving in the dark, especially in the countryside and/or forests.
Thanks!
2015 MP3 500 ie Business
The current gen mp3 headlights use LED technology and are not upgradeable
MP3 500 HPE 2019
MP3 500 HPE 2019
New gen led lights are pretty good, but to make sure it suits you, we are in winter and gets dark sooner, ask for a test ride in the dark also.
One downside to LED lighting I experience is under foggy conditions.
The bright white color of the LED tends to create a blinding effect vs cutting through the fog with lights that have a yellow tint.
@richwa avatar
@richwa avatar
Thanks to all of you that replied!
mp3 500
mp3 500
My Mp3 500 has (2) 12V 55W H7 Halogen Bulbs for the headlights
[part #294353], Both the same for high and low only two on for high beam as opposed to single lamp for low beam. Me thinks the biggest issue for upgrading those lamps would be actual lamp size, heat issues as well as current capacity of wiring. Stock size 55w are available in yellow tint. Osram does have a 65w lamp but I have no information on specs. With all the plastic on our machines the increase in heat would be a deal breaker for me. Just my opinion.
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
When LED bulb manufacturers understand that color should not be for show, but for usability and safety and make H4 and H7 LED bulbs between 3000K and 4000K, I will use them. In the meantime, a good halogen is much better in fog or rain and is fine in regular conditions.
Now it's all show and false lumens, which are only useful for blinding other vehicles, but with light that is not focused where it is needed.
I converted to H4 so I have 2 low and 2 high beams and it works super well at night. I use some Nightbreakers as bulbs and that's it. And I check the charging and with the lights on at idle is only a 0.1v less in the voltmeter, so is fine
mp3 500
mp3 500
What wattage are you running? Those are double filament lamps so I assume there were some mods to the wiring as well as the lamp base themselves? Heat issues?
2016 Mp3 500ie Sport
There was a whole discussion about LED bulbs, watts, and amperage use in this thread. LED bulbs for MP3 500
@dariusz avatar
@dariusz avatar
55/60w and yes needs to be done a change in the wiring. I find in Spain a person that have H4 bulbs with H7 base so not need to do a extra mod in the base 😉
[ Time: 0.0092s ][ Queries: 3 (0.0030s) ][ live ][ 343 ][ ThingOne ]
