First time Vespa owner and new member here. Looking for a touch of advice to help me get going.
Bit of a run down on the Vespa.. Recently bought a 02 PX125 - it had been a display piece in 2 people's living room for 8 or so years, both of which had never even started the engine so any history of the bike is long gone! I bought it without seeing it run (
When I got it, it had a Scorpion expansion pipe on which in turn had 2 main issues, the first being the down pipe seemed too big for the cylinder outlet so was simply blowing, and the second being the exhaust was heavily lined with unburnt oil. A quick google led me to believe this pipe was better suited to a 200 or kitted 125/150 so I swapped it for a used SIP Road 2.0.
A couple of runs up and down the road led me to believe it was ready for its MOT, on the way there suffered what I now know to be a soft seize (at the time having no clue what on earth was happening!). Wasn't pinning WOT but was riding along at 50mph for 8 - 10 minutes when it happened. Fired straight back up after a cool down period, got the MOT and got home knowing it needed a good adjustment (also regularly cutting out at idle).
I've read through the Wiki page on how to tune a carb, gold mine of information that all makes sense. However I'm worried my current set up is at such a mismatch that I'll be chasing my tail. So I'm hoping someone with similar basic hardware could let me know what set up they're using reliably that I can piggy back off and fine tune from there. Just the plug, idle, mixer and air corrector would be much appreciated.
Exhaust: SIP Road 2.0
Air filter has been drilled out
Standard SI 20/20 Carb
Main Jet: 140/BE5/102
Idle Jet: 45 - 140
Spark Plug: B8ES
My initial thoughts were it was running lean due to the soft seize, however the plug is black AND coated in wet oil. I'm also pretty sure its the wrong plug and should be a H series.
