Vespa GTS 300
Vespa GTS 300
Hello.
The Vespa GTS has undergone some changes/modifications over the years.
Regarding the exhaust, between which model years is it possible to share the exhaust?
My Vespa 300GTS is from 2017. It is the model ZAPMA3300.
Can I install an exhaust that the seller says fits models from 2009 to 2014, for example?
And, can I use a Vespa GTS 125 exhaust?
Thanks everyone.
2019 GTS 300 HPE w Malossi
you can't use a 125 exhaust.
For the 300:
the 09-15 is a Euro 3
the 15-19 is a Euro 4
I'm would expect the E3 exhaust would be fine on a E4 bike.
Vespa GTS 300
Vespa GTS 300
For the 300:
Good morning.
Thanks for the information.
However, for example, in this exhaust from this site:
https://www.sip-scootershop.com/pt/product/escape-de-corridas-akrapovic-slip-on-black-edition-2020-s-ve3so9-hrssbl-126419-para-vespa-gts-gts-super-gtv-gt-60-125-300ccm-ie-4t-lc_AKRAPO36?usrc=escape%20vespa%20gts%20300
It says that it works for EURO3 and EURO4, and that it works for 125 and 300.
Will it be a mistake?[/url]
@che-storto avatar
2009 Black Vespa s150
@che-storto avatar
It's a "Slip-on" so attaches to the existing header pipe. Shouldn't be an issue for your application.
You could always send SIP an email or call to confirm......
Vespa GTS 300
Vespa GTS 300
Thanks again!!
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
I would look with a very skeptical eye at an exhaust that they say works well for 125 and 300, the difference is huge in what it has to expel/process.
As for Euro3 and Euro4 exhausts, they are generally interchangeable and it is simply a marketing ploy to sell the newer ones more expensively, but as previously said, it is good to check to be sure.
Vespa GTS 300
Vespa GTS 300
Hello.
Thanks for your tips.
I will search a little bit more!!
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
JoaoPintoReis wrote:
It says that it works for EURO3 and EURO4, and that it works for 125 and 300. Will it be a mistake?
Yeah, mistake in the listing, that one won't fit the 125.
The older 125 GTS in Europe was the same engine as the GT200, with the same crank and head. So if that's the 125 they reference, it should fit. I've used GTS exhausts on my GT200 and they bolted right up.
If it's the Chinese motor with the radiator hanging off the right side over the flywheel, it's not going to fit.
Vespa GTS 300
Vespa GTS 300
Hello!
My vespa's engine is the one in the photo!
And the escape I have is just like photography!
The exhaust in your link (SIP) is correct for you.
[ Time: 0.0093s ][ Queries: 4 (0.0032s) ][ live ][ 343 ][ ThingOne ]
