Bought a 1970 Veloce Sprint 150 - it had the 6volt contact stator i grew to hate. This then pushed me to modernize it a little
full engine rebuild with SKF bearings throughout on new crankshaft, this was coupled to malossi head and piston. New wiring loom from sip vape kit up to sip switch speedo ect.. Basically the electrics are modern with all new switches.
transmission looked ok, but i put a new cruciform in to be safe along with new seals everywhere.
brakes are the old drum type - they seem to work OK, but i had to renew them all at least, i then added 2 carbone shocks to the scoot and put Michelins on the rims.
to finish it off i added 2 wing mirrors and a big shiny expansion exhaust - this was harder than i thought it would be, i had to modify the stand which involved more welding.
In the process of jetting the carb and setting up speedo - taking it slow as i learning as i go.
So if you still reading i going to say thank you to all -- i only get this far by reading what others have done as guidance
updates and questions will follow -- thanks again
