Hi guys!
New to the group! Not long moved down to Bristol with my Vespa, the Vespa stayed down in Bournemouth for a little bit because someone had tried to steal it meaning it needed a new locking system and barrel.. once i got it back it took me a couple of days to notice the headlight no longer works, the small side bulb does and the Green dipped beam is on on the dashboard, but no power whatsoever to the main headlight bulb or blue light on the dash.. I've changed the bulb twice, once because I found a HS1 in it when I first took it off then changed it with a H4. I've also changed every fuse I could see!!! To no avail I'm slowly loosing hope! Cause this be a grounding issue? The mornings are getting darker and I'm gonna need this light soon (if not already) 😬
Thanks in advance!
