@green_60 avatar
GTS racing 60
@green_60 avatar
GTS racing 60
Have anyone put 13in. rims on 2023-2024 GTS300 (US models)? Any problems with ABS n ASR system light up? That included w/ rear 13in. speed toner. I have it on 2021 GTS300 and have no issue, but on 2024 problems!
what tire sizes and pressures?
@green_60 avatar
GTS racing 60
@green_60 avatar
GTS racing 60
130/60/13 f.- 26psi
140/60/13 r - 33psi
That sounds reasonable (was checking that you hadn't chosen some weird combo).
Next thought is incorrect gap between the tone wheels and sensors. iirc it should be around 1-2mm, check all the way around incase the tone wheel is bent. Front and rear.
And maybe use the standard tone wheel
PS, your rear psi is way high
@safis avatar
@safis avatar
We've done it and everything's fine. Only things needed are the special screws for the tone wheel, the axle bush (or machine yours) behind the suspension arm and an ASR re-calibration. No need for a different tone wheel...
[ Time: 0.0084s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
