125 GTS 2024
125 GTS 2024
Hello
I recently bought a new Vespa 125 GTS and then added a seat height lowering kit..
It is now really difficult to put the Vespa on the centre stand… does anyone else have this problem?
MP3 500 HPE 2019
MP3 500 HPE 2019
It is logical as you have lowered the scoot so you are lifting more weight, before weight was higher and less to pull up, also be careful if you have a sidestand because angle will be changed and scoot can tip over.
⚠️ Last edited by flybynight on UTC; edited 1 time
@besupa avatar
@besupa avatar
Panerama I'm sorry to hear that you're having problems with that. I had the lowering done on a 2016 150, but I don't recall it changing the center stand handling too much (Low profile seat and/or lowering link? (Post 2641333)).
That said, lowering would technically mean that the center stand contacts the ground a little sooner and you'd initially have a slightly shallower angle. I've always just used my weight and balanced for the center stand, but that's not the only technique: there's also the grab-the-passenger-handle-and-lift-while-stepping technique. You might find a different approach easier?
125 GTS 2024
125 GTS 2024
Thank you for your interest in this matter… The truth is at 74yrs old I'm not as strong as I used to be.. After I'd fitted the lowering kit (lowered by an inch), my feet are flat on the ground at the lights etc..
But… almost impossible to put the scooter onto the centre stand.. I've completely solved the problem and would like to post pictures and a video but I don't know how..🙈😂
@besupa avatar
@besupa avatar
If it helps, I don't think you're alone in this. I'm sure people more personally familiar with this will come along, but until then you might want to check out some (albeit older) threads that also have some good conversation, links, and videos:
Tips on use of center stand?
Proper center stand technique
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
In my experience in some bikes projects, when I have made modifications that involve lowering the bike, I have had to trim the center stand by calculating how much it lowered to regain the correct angle of movement. It is not easy, because if you cut too much it will not be well balanced and the center stand could retract with a minimal movement.
The same goes for the side stand, which in this case must be very long now and the bike is too "straight" and can cause it to fall over due to balance, but wit the side stand is possible to change the angle of the side stand and doing this compensate the loss of height and correct the angle just by bending it outwards a little.
@abner_bjorn avatar
@abner_bjorn avatar
Do you have a side stand on the scooter? I don't use it all the time, but when I use it, I like it!
[ Time: 0.0078s ][ Queries: 3 (0.0019s) ][ live ][ 343 ][ ThingOne ]
