Hi all
I've recently setup a Koso DR-2 speedo to my scooter (better functionality than the SIP one) and also used the speedo drive convertor that bolts into the normal spot with the worm drive on the forks (I've a PX disc fork).
Some links are:
Koso DR-2 - https://kosonorthamerica.com/product/db-02r-lcd-meter-street-version/
Convertor - https://www.scooter-center.com/en/speed-sensor-digital-speedo-cable-koso-d-jis-type-a-koso-d-jis-typ-a-vespa-vba-vbb-gl150-gs150-sprint-gt-gtr-super-ts125-rally-lambretta-dl/gp-li-sx-tv-black-plug-kobf580000
I'm getting a signal though the speed seems to be displaying about 30% too high (so say 80kmh when it feels like I'm doing 60 kmh).
There doesn't seem to be a setting to say you're using this setup, just the option to enter the tire circumference and the number of triggers per revolution.
I entered 1330mm and 1.
Before I get into a bunch of testing I thought I'd check if anyone has experienced this and/or knows the values to use to get it to work?
Cheers
- Matt
