Vespa px125
Vespa px125
Hi all. I need some help.
I have a Vespa px125 2004.
I have all of a sudden lost lights and indicators. Also rear brake light does not work. Randomly the thing that does work is the main beam! The speedo light works when it wants now. Comes on then goes off again. The horn is fine . Any help would be greatly appreciated.
@mjrally avatar
@mjrally avatar
Did you check your battery? 12V DC or higher. If that checks out look at the fuse next to it, and then the relays behind the battery.
Vespa px125
Vespa px125
Battery is ok I think 12.9 v. The fuse next to it is intact . There are 2 relays behind the battery. Which relays are these for ?
@safis avatar
@safis avatar
Euro market PX has everything running on AC except horn and starter. Check the stator plug on engine junction box. They tend to disconnect or melt...
Vespa px125
Vespa px125
Ah ok. The engine runs fine. Would that still happen if that plug was defective?
@safis avatar
@safis avatar
Yes, engine runs even if the plug's disconnected...
Vespa px125
Vespa px125
Mine doesn't appear to look like that to be honest . The 2 rubber grommets attached don't have plugs. Just wires going in I think
@safis avatar
@safis avatar
Undo the rubbers, undo the screw and it opens up. The plug's inside...
Vespa px125
Vespa px125
This screw? The plug inside ?
Vespa px125
Vespa px125
The plug has a cable tie holding it together for sure
[ Time: 0.0084s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
