@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
I'm fitting a Malossi 185 kit to my new Euro 5 Sprint. I'm keeping my standard exhaust, but I know the Catalytic Converter will restrict the performance.
Is anyone running this set up, and has anyone removed the Catalytic Converter?
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Been looking at this for my Euro4 Primavera. Collecting the kit tomorrow.
You will have to sacrifice the down pipe to ditch the cat that as it is designed to be not removable.
Together with the Malossi ECU the power upgrade of the kit will be quite considerable, like >50%.
I am not sure what removing the cat will do; cannot see it being much because the muffler is quite restrictive; quite possibly more so than the cat!
Imo you would need to go full exhaust replacement with decat pipe to have the most result.
´Most´ being disappointing from what I know.
Very curious about the results if you should mod the exhaust.
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
I was thinking air flow. I had an old 2008 LX about 10 years ago and fitted this kit. Worked brilliantly, but my old LX was a carb set up, and no Cat on the standard exhaust I was using. A lot simpler set up. I was wondering what difference there's going to be.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
on the fuel injected models, the mapping must be adjusted. Hence the need for the ´Forcemaster´.
There is a thread with a dyno test of a kitted 150cc 946 on here somewhere. Very interesting read.
What I find surprising is that there is virtually nothing written on camshafts here. Those are to a four stroke what the exhaust is to a two stroke.
Polini offers one for the 3V engines and when fitting the cyl. kit it would be a doddle to replace as well.
I would fit one wáy before faffing with the exhaust.
https://www.sip-scootershop.com/es/product/arbol-de-levas-polini-1694002-para-vespa-lx-s-primavera-sprint-3v-ie-125ccm_P1694002?usrc=camshaft
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
All my upgraded parts have been ordered by my main dealer. They'll fit everything, and set the mapping for use with a standard exhaust. I prefer a standard exhaust for the quietness and ease of maintenance.
My thoughts are if it was possible to modify my standard exhaust in some way to tweek a little bit more power that is available via the mapping setting of a sports exhaust.
A small cc four stroke exhaust doesn't give the performance upgrade compared to a similar two stroke set up, so a far simpler design.
I'm not looking for a much faster Scooter. (I'd get another GTS300, didn't like it, to big and heavy for pottering about) just wanting a tad more torque and a slightly faster acceleration, if needed.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
and there is not
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
. . . . . why??
A sports exhaust helps to increase airflow.
A catalytic converter will reduce airflow.
If you were to remove the catalytic converter, would that not improve performance?
So, what's the benefits of a four stroke sports exhaust compared to a standard factory fitted one, designed to cut emotions? I can think of weight, and, if you're into it, noise.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Thís is the crux of why not.
The muffler is the bottle neck.
The power gains of a sports exhaust/cat are disappointing. Even a full race decat Akropovic will net very little extra efficiency.
The ´secret´ of it lies in the valve timing. It is designed to pump into a slow flowing exhaust system.
Again, have a look at the 946 tuning thread. It starts the base line with a sport exhaust on a standard engine on the dyno.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Here´s a SIP ´racing´ pot without cat.
They themselves rate it has minimal increase in efficiency only.
https://www.sip-scootershop.com/es/product/escape-racing-sip-series-pordoi-para-vespa-primavera-sprint-125-150ccm-ie-3v-4t-ac-para-piaggio-3v-lem-euro3-iget-euro4-euro5_MV22030R?usrc=escape%20primavera
I woúld fit it if the camshaft I am looking at suits my scoot. For increased opening times it doés make sense.
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
I totally agree with you on the benefits of a sports exhaust, but why does the Force master have 4 maps, depending on the exhaust set up? (standard and sports)
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
as I do not know what the difference in the mappings is, I cannot answer that.
With the standard camshaft I am not going to faf with the exhaust.
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
We could be on the road roughly the same time, it'll be good to exchange notes.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
will be happy to.
Just ordered the Polini camshaft.
Would be silly to fit the Malossi kit and possibly fit the camshaft later. When fitting the kit the extra effort is not worth mentioning and it will make way more use of the extra cc.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
ah and Scooter West had a good suggestion for if the mixture remains lean; fit an injector from a 250/350.
Did same with car tuning and it totally fools the ECU into giving more whereas the loop of the lambda will keep it from too rich.
Part# 8732885 (PIAGGIO) should do the trick.
I may do it later as the 125 injector will be rather maxed out.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Any progress to report john71 ??
I have all the goodies in now and am looking at the air intake so can do all in one go.
@john71 avatar
Vespa Sprint Auto
@john71 avatar
Vespa Sprint Auto
My Kit is out of stock in the UK, so coming from Italy. Hopefully here next week.
I've also got a Yacht Club kit to fit, that arrived last week. (I know they never done a Sprint Yacht Club, but It'll all fit, and my Sprint is plain White)
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Fingers crossed then and indeed all the same engine really.
Will keep you updated in the thread on mine.
Meanwhile waiting for a shipment from Italy as well; an air filter cover from VMC for the NSM.
p.s took 3 days only for the VMC parcel to arrive up here in the mountains Clap emoticon
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Buenas john71 here is the proven answer to your exhaust question:
1 to 2,5% power gain.
On a 125 that would be how much hp?
For 750 - 1300 €uros.
SIP has the ´Pordoi´ for a sport damper but take a risk with quality and the power gains will be minimal.
[ Time: 0.0117s ][ Queries: 3 (0.0037s) ][ live ][ 343 ][ ThingOne ]
