Hello everyone,
I am running into an issue with the famous roll lock system. I found a similar post on this forum but no solution so i hope i can rekindle the discussion and maybe even get the needed help to solve the matter.
When trying to engage te roll lock i get a steady orange and red light on the dash accompanied with a steady beep for 5 seconds. I found the video on youtube explaining beep codes but this scenario is not part of it.
There is a brand new battery installed and even though the video shows 12.5 volt in the beginning, it also happens when it says 13 or even 14 volts with engine started.
I did not check or replace any cables/plugs/relais but i found 2 plugs which i was wondering why they are there and not connected to anything? not sure about the purpose of those plugs and if they should be connected to anything.
See attachments for more details.
Thanks in advance!!
edit: it seems i cannot upload the video so instead i have uploaded on youtube: https://youtube.com/shorts/nzAgsf4KcAk?feature=share
