2018 Vespa Primavera 150 ie / Sprint150
Facepalm emoticon Hi! My lovely puppy chewed up our Master Key, so the little important piece in the middle is gone, but the key is still "usable". Around the same time, we used AAA to move our Vespa out of NYC to Long Island for winter, and the driver "lost" our everyday/spare key.
So we have our brown master key without the "code". Would appreciate some guidance as to WHAT THE HECK you would do!!!! Thank you!
MP3 500 HPE 2019
MP3 500 HPE 2019
To me sounds like you are up for a virginised ECU and keylock to get a new set of keys from your vespa dealer
@syd avatar
@syd avatar
Is there a battery in Vespa keys? I haven't opened mine, but figure a battery wouldn't be good for any dog's insides.
2019 GTS 300 HPE w Malossi
No.
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
Normally you only have to wait 36-48 hours...
The service partner will hopefully be insured for such cases?
You need a sieve... and that 36-48 hours.
BTDTGTTS...
jimc wrote:
You need a sieve..
for the curious the GTS 300 HPE (MIUG4) uses a PCF7936 which is 12x6x3mm.
the Prima/Sprint (EFI) of about your era I think uses a T5-11 which about the same size.
Do you still have the chip in the key, and what do you mean by it's usable? Can you start and run the scooter with it? Can you use it to cut another master key?
If you still have the chip, We have the chipped Master key and two tumblers for about $30. You can switch out the chip in the new master key for the one you have, and replace the tumblers. Then you would need to get either an OEM blue/black key, or one of the clone keys that are out there now. This is also nice to have around in case anyone ever tries to start your scooter with a screwdriver.
[ Time: 0.0125s ][ Queries: 4 (0.0041s) ][ live ][ 343 ][ ThingOne ]
