GTS 300 HPE (MY 2019 EU)
Hello all,
I changed my disc and wanted to change de pads as on the metal. And I rounded off one of the two caliper pins.
So I ordered the same caliper, should come soon.
I will have to quickly remove the banjo and bolt it to the new caliper.
Can this kill the ABS console? Is there something I should be aware of when doing this?
Thanks a lot!!
@jk_single avatar
Vespa P200E, Fly 50, Vespa S50, Vespa GTS 300
@jk_single avatar
You obviously need to bleed the caliper but this is just like any other Vespa, abs or not. Just open the bleed screw and let it gravity bleed. Keep the reservoir full, to get air into the abs system might lead to a world of hurt.
Thanks a lot JK! Ok let's do it as it should and we see if it fails.
[ Time: 0.0126s ][ Queries: 3 (0.0022s) ][ live ][ 339 ][ ThingOne ]
