Posts: 1680 Location: Denver |
You should be able to get at it by removing the right lower side panel and pulling the seat bucket. 10mm nut and 2 screws, maybe T25 for the panel.
Posts: 46413 Location: Pleasant Hill, CA |
The 10mm nut is behind the rear of the lower side panel, just underneath the rear tail light, Remove that nut and the two screws at the front of the panel. Pull the rear of the side panel out towards you to about 90 degrees, then it can free itself at the front.
Get it done once, and you'll never forget. |
Actually I need to access the cooling hose, which body part/s do I need to remove to get to the coolant hose and replace it . Thanks 🙏
To get to the whole hose you'll need to remove the whole knee panel that includes the glovebox, and the floorboard.
How about posting a picture of the hose you are talking about and we can quit guessing. Have a read through this, it might help.
Need Help with 2012 GTS 300 Super Hose Part Number. |
Thanks JMC, I ordered the hose and clamps from scooter west, now to take apart the body to get at it😬
Abner——
COOLING HOSE (ENGINE RETURN) GTS/GTV 250 & 300 (623922) **CONNECTS IMPELLER TO LOWER RADIATOR JUNCTION R/H SIDE OF SCOOTER UNDER FLOORBOARD** (623749) |
