Vespa et2 50cc
Vespa et2 50cc
Hi. Finally i decided to made my vespa high end. So 1st question which cylinder kit i should look for price and reliability. Next i can buy a polini high speed vario and also want to put a 3g for race clutch so is there any advices for transmision amd adjusmemts of these things and how many g i need to put in vario. I have 17.5mm stock dellorto carburetor so should i swap for the 19 or 17.5 will be good?. And the last one question is exhaust, i want to put used yasuni r but maybe therw is some better options. Thank you.
@dvh1150 avatar
2024 300 GTS "Classico" + 2001 ET2 50
@dvh1150 avatar
Howdy! As a fellow ET2 50cc owner, I just wanted to jump in and wish you well. I'm about to tackle a similar project with mine, though more "street" oriented than "full race." At 70, the thought of doing a wheelie -- intentional OR accidental! -- would scare the hoozis outta me! And due to some fairly restrictive laws here in California, I'm gonna go easy and just hot rod my scoot as much for a lark as for anything else.
I hope you'll keep posting here on your progress. I'll be really happy to see what you're doing. I'll even keep you posted on my progress, if you want.
Cheers!
Victor
@az_slynch avatar
@az_slynch avatar
lileldar wrote:
Hi. Finally i decided to made my vespa high end. So 1st question which cylinder kit i should look for price and reliability. Next i can buy a polini high speed vario and also want to put a 3g for race clutch so is there any advices for transmision amd adjustments of these things and how many g i need to put in vario. I have 17.5mm stock dellorto carburetor so should i swap for the 19 or 17.5 will be good?. And the last one question is exhaust, i want to put used yasuni r but maybe there is some better options. Thank you.
A couple of observations:
1) Yasuni R has good pull for a sport pipe but runs out of breath around 10,500 RPMs. It's not quite a good match for either carb, but I'd go 19mm if you stick with a DellOrto. A PVHB 22 and a Yasuni C10 might be a good option for a couple more revs. A Yasuni C16 is about as high as you want to go for street use and makes good revs, but does so at the expense of low end torque
2) Avoid Airsal T7 kits. The pistons are made of soft alloy and don't last long at engine speeds over 9,000 RPMs. The cylinder is a good sport kit and it can be beefed up by subbing in a Stage6 Sport piston. At that point, you may as well invest in a better kit. I'm fond of the Stage6 Sport MK.II, but stuff like Polini's Contessa is easier on the wallet.
3) The HiPER2 engines block can be configured for an air-cooled or water-cooled top end. The casting has the water pump impeller housing cast into it and can be used if the pump shaft well is drilled for use. Water cooled cylinders can net an extra 2-3 horsepower and run longer at high RPMs, but take more planning due to needing a radiator/fan/plumbing.
4) Aftermarket crankshafts are a smart play if you're running your engine at higher RPMs. Stock crankshafts are good up to about 10,000 RPMs while performance versions can handle 16,000-18,000 RPMs. You can use kits with bigger piston pins (12mm) with the right crankshaft. Consider your desired performance profile before choosing a crankshaft: Low primary compression (LPC) make for a smoother and more streetable engine, while high primary compression (HPC) give peakier power more suitable for a track.
5) Find a competent machinist to lighten your flywheel by 90-100gr. It will make the scoot feel a lot sportier without having to go too low with the variator weights.
⚠️ Last edited by az_slynch on UTC; edited 2 times
@pinkscooter avatar
@pinkscooter avatar
On my ET2 I used the DR cylinder, I usually use Malossi but I wanted to try it. I believe I have a Dellorto 19mm carb. Its okay with the stock exhaust but I did try the Gianelli reverse off of my SR50, with some CVT tuning and re-jetting it was a decent machine, loud but it moved.
@tbrduc avatar
GTS250ie. Malaguti Yesterday, Motron Medalist, others
@tbrduc avatar
Let me get this straight.
(I have a 2T 49cc also)
You want to take a 49cc that already does gps-measured 45 mph…only weighs 170?
It puts your butt maybe 18" off the ground.. is about 4' long.. and you wanna make it likely do 70?
Did i interpret all this properly?
Because if so… HELL yeah! My kinda fun!
I'll be watching!
Laughing emoticon
@dvh1150 avatar
@dvh1150 avatar
I'll be watching!
Laughing emoticon
While I agree with you on many levels (fun IS where you find it!) I just want to be able to ride my ET2 out here in Palm Springs/Desert Hot Springs/Cathedral City, etc. without having to pull over and let a line of cars pass me as they flip me off for ONLY going 45 or so. And I AIN'T talking 'bout the freeway!
Victor
@tbrduc avatar
@tbrduc avatar
" etc. without having to pull over and let a line of cars pass me as they flip me off for ONLY going 45 or so."
True enough, indeed.
But what i know of az_slynch, i feel like he's talking about creating something that will… "make the jump to hyperspace!"
So the cages look in disbelief.."What the heck was that?!"
az_slynch Ammirite Sean?
But, im not sure about lileldar (OP)
Still, i'll be watching because.. i never met a horsepower i didnt like!
@az_slynch avatar
@az_slynch avatar
I tend to tune for "sporty but liveable". The last two scoots I built for friends were set up to daily ride and still use the electric start, a bystarter and the autolube system.
Both scoots rev out around 10,750 RPM, though the kits can handle 14,000 and the crankshafts are rated to 16,000. Each could rev higher and go faster, but cylinder life drops dramatically. Both scoots could be geared lower for higher speed, but both owners are bigger dudes and I spent plenty of time fiddling with the final gearing and CVT in order to strike a balance of good acceleration and ample top speed.
Tuning 2T 50s is fun due to the potential of displacement versus achievable speed. It's quite possible to get a 50cc to run at 50mph. It's even possible to get a 70cc to 70mph. Not many other scooter displacements can achieve that; I'm pretty sure my LX couldn't hit 150 if I dropped it out of a plane!
The other big kick is the scaling of power gains: how many other other engines can you make 6-8 times the factory power without burning a small fortune? I don't think there are that many.
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
This guy on YouTube managed to get 60mph GPS without going too crazy.
Our LX 50's are mostly 2T (same engine as the later et2's)
?si=XfoPzkw0xox67YVe
The Yasuni R will hit the bodywork on an et2, you can use a couple of riser kits on the shock but then your centre stand won't be any use.
I took it off and sold it. You could adapt it with a welder I'd guess.
@tbrduc avatar
@tbrduc avatar
Sorry to hijack this thread, but what i like best about that video… they dont block the passing lane! However, i would not have passed so close to that tanker. Many years of riding full-sized bikes has taught me to stay half a lane away from a vehicle where possible.
The scooter is slick also!
And now, back to original point of tweaking a 49cc 2T!
[ Time: 0.0105s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
