In my Vespa PX-150 fuel tap (connected with the carburetor) when I tight with the screw with it, after 5 or 6 threads the screw doesn't tight properly . The threads of the carburetor are faulty which cause fuel leakage from that area and come down to the engine bottom side and drop drop fall in the floor . Please guide me that how may I tight the petrol screw with the carburetor properly the threads are free even i full tight it ? Please guide me.
A picture for understand is attached herewith.
@garncarz avatar
@garncarz avatar
Chase the carb threads with a bottoming tap? Use a shorter bolt?
@xperimental21 avatar
Super
Super
The last thing you can do is to rebore the thread hole, then make a new bigger thread and use a bigger bolt, for example M8 bolt.
PX150E
PX150E
The threads may have been cross threaded. Inspect/change the gaskets or add an additional gasket to prevent the bolt from bottoming out.
Thanks all for the replies. Yes the options are good to apply. Well "xperimental21" if I rebore the thread hole what kind of tool may I use ?
" sp949 " About the gaskets, this means the to change/add additional (red tiny rings) close to thread hole ? Please elaborate it a little bit .
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
@roland87 avatar
@roland87 avatar
there is no place for M8 bolt
I think it is much batter to replace it with the new one .
[ Time: 0.0101s ][ Queries: 4 (0.0024s) ][ live ][ 343 ][ ThingOne ]
