1968 Sprint 150
1968 Sprint 150
Moving to a new storage space and found the slightest oil drip from the casings and then down towards the rear brake lever and then to the tyre. Literally only 6 drips but has anyone ever solved this slight leak with the best gaskets money can buy?
Yes, probably more than once. Not sure what it has to do w/ your six drops of oil though. More likely just a seal that's not new but still doing pretty good. I think what you are experiencing is more or less normal unless over just a couple of days. How long was it stored?
1968 Sprint 150
1968 Sprint 150
Stored since January.
@moto64 avatar
@moto64 avatar
If it has just been sitting, the leak has to be at or below the oil level which is way down low at the fill point.
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Some of those fiber drain plug gaskets weep oil. I use 8x14mm copper washers now.
1968 Sprint 150
1968 Sprint 150
engine case using copper gasket instead of fibre gasket might work better.
@ray8 avatar
@ray8 avatar
"If doesn't drip it isn't a Vespa."
Not my quote Razz emoticon
I have three bikes that drip a bit.
One has no carb filter and jetted on the rich side. Blow-back runs down to the floor (instead of being caught by a filter), like a few drips or so of oil (fuel evaporates before hitting the floor) over a week after riding.
Another has a few drips leak from idk where between the cases. PO rebuild with a paper gasket.
Another leaks from the clutch cover/lever. If you're seeing oil on the tire I'd suspect that. Definitely worth inspecting. Oil on the bottom of the lever is a tell.
Older cases can be sealed pretty damn well with VERY LITTLE sealant and a fiber Piaggio gasket.
There's also the rubberized aluminum Athena gasket.
[ Time: 0.0087s ][ Queries: 3 (0.0016s) ][ live ][ 339 ][ ThingOne ]
