Hi ◡̈ finally I've bought a new Vespa. Previously I asked for your thoughts on the colour as I wanted a tie breaker between 'black' and 'orange'. Well, I opted for the orange and am very happy with it.
Now see attached photos, is it normal to have this much play between the panels?
Particularly on the side, the bottom panel juts out by about a one cm or a 1/3 of an inch. And that's about twice as much as the opposite panel juts out. They're not even.
And in the other attached photos, there's a decent gap between many of the panels.
Finally, is it normal for the throttle grip to have play?
It will jiggle side to side on the handle bar by about 1/2cm and it will play back and forward by the same amount before biting on the accelerator. I've not ridden many bikes, but on other brands the throttle grip was precise, not 'loose' and 'jiggly'.
Thanks in advance!
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
Yes!
Welcome to the world of Italian engineering and Luigi's manufacturing quality.
To be fair, it has to be said that it is intentional that the bottom Panels belle the side jaw should protrude a little further. So it's not a bug it's a feature.
However, they should be even on both sides.
But wait until you discover the free extras from Luigi under the running board...
@mike_holland avatar
GTS300 Super 2023 Beige
That side panel looks as though the rubber locating pins are not quite home, which would also cause that small gap at the front. There are three rubber locating pins behind that panel, and they can be difficult to push all the way in. Try giving the panel a hard thump with the base of your hand, but loosen that screw at the front first.
Regarding play in the throttle, I haven't experienced that much lateral play, but mine also needed a fair twist before the engine responded. I adjusted my throttle cables to eliminate just about all the play, for an immediate throttle response. But those adjusting screws are rather difficult to get at. You need to slacken the upper one a bit and tighten the lower one.
GermanGTSDriver wrote:
Yes!
Thanks for the advice!
Having poked around under the running board, etc, I have a notion that a lot of the rust issues people complained about in the past are really to do with ingress from the radiator vents, and the steering head. The paintwork inside the body is very thin. It looks like a 'must do' to open up a new vespa and rust protect all the surfaces before the water inevitably gets in...
Many people do just that, especially in the wetter parts of the world (UK etc).
Thankyou! I followed your advice and a hard thump popped the side panel in.
[ Time: 0.0125s ][ Queries: 4 (0.0045s) ][ live ][ 343 ][ ThingOne ]
