I have a 2008 GTI250 that cut out on me yesterday it did restart. I replaced the kill switch a few months ago because it was acting up. When I push the kill switch when it is in the on position and the bike is running the bike cuts out is this normal?
Outsider wrote: I have a 2008 GTI250 that cut out on me yesterday it did restart. I replaced the kill switch a few months ago because it was acting up. When I push the kill switch when it is in the on position and the bike is running the bike cuts out is this normal? |
Jess when the switch is in the on position and I push while in the on position the bike shuts off I am not moving it to the off position.
Posts: 2175 Location: Oceanside, CA |
Outsider wrote: Jess when the switch is in the on position and I push while in the on position the bike shuts off I am not moving it to the off position. |
Posts: 3807 Location: Minneapolis USA |
RIP
Yes, the famous Kill Switch. Many a tale to tell.
When I got back into two wheeling 22 years ago, my Scarabeo 150 would not start and was totally dead. I rented a pickup and hauled it back to the dealer. The nice service guy, at the dealer, helped me balance the scoot as we rolled it on a ramp off the back of the pickup. He looked at the scooter, then looked sideways at me, flipped the kill switch off and started the scooter straight up. Over that same period of time, I have helped at least 4 riders in my group who could not start their scoots after a rest stop. Flipped the switch, and off they went. Ba dee, ba da - Giddy Up! Bob Copeland Happy Halloween Everybody
The Kill Switch Culprit.
Outsider wrote: Jess when the switch is in the on position and I push while in the on position the bike shuts off I am not moving it to the off position. My standard advice is to roughly jab it on and off a dozen times to make sure the contacts are relatively clear. |
Posts: 2137 Location: Pretoria, South Africa |
Nowadays, I turn the kill switch off and on again whenever I start the GTS in the morning. That way, I don't forget to check that it isn't OFF.
Okay thanks everyone I guess as long as it restarts after shutting down all by itself. Unless I am going 75MPH on the highway or on a group ride with my wife on the back. After all these years why can't I attach a Video? Without having to go thru Youtube bullshit!
GTS 300ie, Honda Integra 700
Posts: 1779 Location: Sunshine Coast, Australia |
I just cut the wires and join em together. On, off, rusty, clean, falling apart - makes no difference and guaranteed to work for the life of the bike!
Outsider wrote: After all these years why can't I attach a Video? Without having to go thru Youtube bullshit! YouTube does an excellent job of managing videos. So does Vimeo. And both seem to be able to afford the storage space, generally by selling advertising. Notably, Modern Vespa has no advertising to speak of. And generally, that's a good thing. ⚠️ Last edited by jess on UTC; edited 1 time
Positive
Call me weird, but I almost never use the kill switch to shut down my bikes after riding them....in fact, I can't remember the last time I did it. In an emergency, yes, I would use it, but I just use the key...assuming it has a key, that is.
2009 Black Vespa s150
Posts: 413 Location: Thornhill ON Canada |
I must be normal then 'cause I always use the "kill switch" to shut-off the "bike"(s). I believe doing this has a few advantages.....
Positive
Che-Storto wrote: I must be normal then 'cause I always use the "kill switch" to shut-off the "bike"(s). I believe doing this has a few advantages..... Either way, the result is a room temperature bike. In my mind, as long as I have to turn the ignition keys to 'off' to shut down the engine anyway, also flipping the kill switch just seems unnecessarily redundant. I have always viewed a bike's kill switch as more of an emergency shut-down device. My Triumph Rocket is our only bike, of four, that uses a keyless fob to start it, and is 'lighted up' by a combination kill/start rocker switch on the right bar housing, so, unfortunately (to me), I am required by it's 'Big-Time-Super-Space-Technology' to shut it down with a.....kill switch.
Positive
I own/ride more than one "bike" and the kill-switch is in a slightly different position. By always using the kill-switch this Old Fart develops muscle memory because I can't rely on my grey matter to react fast enough in the event when the kill-switch is actually needed. (Holy cow that was a run on sentence
Positive
Posts: 5371 Location: Tempe, AZ |
The MSF course encourages using Kill Switch, then key, but it didn't stick, so when my bike doesn't start, I'll spend an inordinate amount of time figuring it out before realizing what really happened.
Another never use the kill switch to shut down a bike guy here. Kill switch is for emergencies.
Been riding a very long time, so long I don't remember if there is a reason. I suspect that it was this: Why use two switches to shut the bike down when one will do? |
Red Devil SH150i (11,000)
Posts: 3341 Location: Orange Park Florida |
Syd wrote: The MSF course encourages using Kill Switch, then key, but it didn't stick, so when my bike doesn't start, I'll spend an inordinate amount of time figuring it out before realizing what really happened. |
marret wrote: I suspect that it was this: Why use two switches to shut the bike down when one will do? I have experienced this on a number of occasions, where I had an actual emergency and needed to shut the engine off right now (example). My muscle memory took over and I flipped the switch without hesitation. Would I have been able to react as fast had I not always used the kill switch to shut the bike off? Maybe. Maybe not. But the habit costs me nothing, and as a bonus it keeps the switch contacts clean.
Positive
jess wrote: The general philosophy of always using the kill switch is so that it becomes automatic in an emergency, when you might otherwise be panicking or even partially incapacitated. I have experienced this on a number of occasions, where I had an actual emergency and needed to shut the engine off right now (example). My muscle memory took over and I flipped the switch without hesitation. Would I have been able to react as fast had I not always used the kill switch to shut the bike off? Maybe. Maybe not. But the habit costs me nothing, and as a bonus it keeps the switch contacts clean. I choose not to and been riding for 50 plus years. At this point in my life, I am ok with what I do. I have had to use mine a couple times in emergencies and managed to get it done.
Positive
One area where using a kill switch to stop the bike is with the new new keyless Vespa's RST 22's . Ive already seen on here and fbuk, where folk have pushed the bike into the garage, hit the kill switch before removing gloves lid etc, then walked away.
With a physical key you would shut down the ignition system with keyless, it just sits there flattening the battery |
marret wrote: I choose not to and been riding for 50 plus years. At this point in my life, I am ok with what I do. I have had to use mine a couple times in emergencies and managed to get it done. |
JBacklund wrote: So!.....the question remains. |
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
Posts: 547 Location: CCS-Vzla |
Shebalba wrote: It really depends on what kind of motor oil you're running. |
Primavera 150S (for sale), and GTS 310
Posts: 1196 Location: North Central Connecticut |
Olde Rider wrote: I use 90 weight gear oil in my engine. Is that too thin??? |
Liberty 150
Posts: 27 Location: North San Francisco Bay Area |
When I picked up my new Liberty 150 from Rockridge Two Wheels the sales person said to mostly use the key to turn off the engine to prevent potential future issues with the kill switch.
To points made earlier, this means I'm confused for a few seconds if the bike won't start because I unknowingly bumped the kill switch to kill. It takes a moment for me to think to confirm the switch is switched to alive. In other memories, does anyone who drove an air-cooled Volkswagen remember the red "B" button on the dash? To me and my friends that was the BLAMO! button, used to blow up evil cars and evil drivers in front of us. Marc |
