- Brake light works correctly. Kick stand is up. I'm holding the break when I try to start it. These are the most basic things, but worth saying.
- All fuses checked, even the "hidden fuse" that I have seen come up in discussions.
- The voltage regulator appears to be good. After charging the battery, voltage was:
* off: 12.3
* idle: 12.7
* throttle: 13.2
* I pulled the voltage regulator out and tested the flow of the current to make sure the current was not running in any directions it shouldn't be.
- Parasitic drain. Difficulty starting, but runs fine once it's going. Headlight dims when I'm hitting the throttle. When I turned it off, the battery drained so quickly that I couldn't start it up again. I hear a rapid clicking when the battery is dead and won't start up.
- Overheating / burning smell (coolant and oil levels fine. No leaks. Temperature goes up to 65% on the gauge when riding for about 20 min.
- Disconnected the light under the seat and battery still drains.
Keeping it on a battery tender is not an option, as I live in the city, on a busy street, without access to an outlet. I'd like to fix it so that I can let it sit outside for a few days at most without draining. I don't plan on letting it sit for extended period as of time.
Resources:
- looks like the stator could be behind the water pump housing:
- "Hidden fuse": Hidden Fuse DONE - pictures and all
- BV 500 Workshop manual: https://absolutelyscooters.net/manuals/Piaggio_BV500_Service_Manual.pdf
* Removing the stator covered in page 30-33 of engine section
- Removing a stator on a scooter:
Where is the stator? It looks like it's so simple on most scooters. But, if my understanding is correct on this model, I have to drain the coolant, remove the water pump, the casing, remove the side panel. When I went look at doing this this, the exhaust pipe is in the way, so I would have to remove that too. I feel like I'm looking in the wrong place based on everything I've read and seen about changing a stator. One post (that I can't find now) someone said it's so simple on this model. I don't see how that is so when it feels like I have to tear everything apart to get to it.
I called the local dealership asking about part number for this model, and one part I needed but can't get is the removal tool. But again, it looks like that tool isn't needed based on the workshop manual above, making me think I'm looking in the wrong place.
Working on it has been frustrating because I live on a busy street the job keeps getting bigger and bigger. I have been getting up early to work on it, but I'm close to throwing in the towel and just taking it to a shop, giving them the part, and asking them to do it because it seems like a big job the more I take the scooter apart to get to this stator.
Should it be this difficult to get to this part, or am I looking in the wrong place?
