Vespa VB1T
Vespa VB1T
I might be buying this VB1t. My primary concern is this. There is a slight crinkle/crease in the body. Is this totaled? Would you ride this as is?
Thanks!
Ian
VNB VSC VMA VSX - o9c vbc vmb
Moving to NSM.
Welcome!
That crinkle in the tunnel would gave me great pause. Please post more pics for a better idea of what is going on. Get a laser level and shoot the center line of the the bike from behind making sure the laser sits on the seam and on the fork column dead center.
I wouldn't feel comfortable with a bend there honestly.
@gickspeed avatar
@gickspeed avatar
Legshield has been pushed in. While not totaled, it would need to be placed on a jig and bent back into place. I would skip it and look for another as there are plenty of these bikes in the USA.
if you are looking for a widebody project, i have several Sears Allstates from 1955-1957 in Indianapolis.
Vespa VB1T
Vespa VB1T
But- if I wanted this frame/body in particular. Like I love the patina and the paint, how could I diy save this? Or is this just not possible?
parallelogramerist
parallelogramerist
What's your experience with automotive bodywork and and metal fabrication? It kinda sound like you have an emotional attachment to this particular frame that you're thinking about buying?
Vespa VB1T
Vespa VB1T
None, but my dad worked in body shops and can do all that stuff. I am just asking the knowledge base if I'm being dumb.
@safis avatar
@safis avatar
Jig and a porta power ram…
'74 50s x3 '87 PK125XL '92 PK50XLS Plurimatic - & - '58 AllState '68 Sprint '66(?) Super125 '72 DanMotor Super150 and '04 Bajaj LML hybrid
I like VB1s, if I was in the market and no serious rust and price is right, I'd take a chance and do what Safis suggests & then check w/ Birdnest's laser. But would need to see first!
parallelogramerist
parallelogramerist
I just had to one up you. I took a screenshot of my short video. There's a John deere tractor on the other end of that chain.
@finyoshi avatar
@finyoshi avatar
I'd say that frame is beyond repair.
Sure it can be forced back, but it will not be the same as it once was. Especially knowing that the shape is crucial to the rigidity of the frame.
You're right of course, but really depends on 1 further inspection, and 2 intended usage and motor. These old wide-bodies are already much stronger and stiffer than especially older VBAs etc and even likely your newer P series. I have 2 VB1s , one started as an wrinkled mess but both are originally strong as Hell and tuff as nails. Piaggio saved money w/ more efficient large frame design, but not as stiff, fewer body pieces and less steel
You see cars w/ unibody frames straightened and laser aligned all the time and they don't seem to have a problem if done right. It's not really bent that far! I have a friend w/ body shop who does this stuff & he knows this would be minor. But would I prefer a car that hadn't had frame damage repair? Of course!
Yep, fatter and stiffer!
@safis avatar
@safis avatar
If done correctly, rigidity is not an issue. I've done a worse and more complicated ET4 125, 10 years ago and it's still around…
Vespa VB1T
Vespa VB1T
Thanks everyone- you've given me a lot to consider.
@declan avatar
1964 Vespa GS160, Fuji Rabbit S601, Lambretta LUI, 1958 Vespa VB1
@declan avatar
Even if the damage is too difficult to repair it may be worth buying for parts. Especially if you are going to do a wide frame build. The speedo and various trim pieces are worth money, the forks and various other bits would be nice to have.
@orwell84 avatar
@orwell84 avatar
Have your dad give it a look. Have a good look inside the frame tunnel for rust. If it were mine, I'd give it a bash just for sport.
[ Time: 0.0131s ][ Queries: 4 (0.0045s) ][ live ][ 318 ][ ThingOne ]
