@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
if one calculates the gains in %s it is directly applicable to any modern 4stroke Vespa model Clap emoticon
I in particular find the Remus test with/without db-killer híghly informative ROFL emoticon
Enjoy:
That's expensive horsepower.
The OEM Sport Exhaust is the same Arrow exhaust as the Polini, but with a more expensive sticker, so they should perform about the same.
but if the oem sports exhaust is installed by a dealer then they are supposed to also install a different mapping using pads. But was this done in the above vid ...
Vespa GTS 300
Vespa GTS 300
There is no indication of this in the video. But since all the tests were carried out with the same vehicle, consider the following: Once the update has been installed, it is not so easy to remove it again... Meaning: either the original Vespa sports exhaust was tested last (in which case an update could have been made). If the original Vespa sports exhaust was not the last to be tested, then a possible update would also be installed for all following tests. Or the update was not carried out at all.
I would assume that the new mapping has not been installed.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
Indeed Motovista
A cylinder kit, camshaft, ecu ánd variator together cost less
It is just that it is easy, visible, audible and ´me too´must have/do.
Do not expect the supposed mapping to make a lot of difference if at all.
Regardless of mapping, the benefit is/will be mostly subjective: In sound and looks.
For the performance it is simply not vfm. Different weather conditions have more effect.
As to the weight advantage, that can be achieved a lót cheaper
All in all a matter of personal taste/preference and, I am sorry to observe, not much else. The removal of the dB thing was ROFL emoticon
@randyjaco avatar
2019 GTS 300
@randyjaco avatar
2019 GTS 300
There was a time when adding fancy exhausts made a significant difference. Now days, for the average guy, you are pretty much adding an expensive noisemaker. Razz emoticon
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
There is no discussing taste so both sound and looks are down to personal preferences.
The test pretty much definitively proves that the pudding is mostly thát, not performance.
The, highly informative, thread about fitting a 185 Malossi kit on a 946 already pointed firmly at it but this is with a base line of the OEM system.
@petrus avatar
P200E DN 1982
@petrus avatar
P200E DN 1982
I have fitted the Polini (which was discounted; 476 € incl. delivery) and it came with Polini branded paperwork with the registered manufacturer being.... Arrows Special Part s.p.a.
As such I think any measured performance differences should be seen as within the standard deviation of the lot. It is marginal anyway.
One aspect I have not seen mentioned is that even a bit better flowing exhaust system has a marked (cooler) effect on the operating temperature.
[ Time: 0.0132s ][ Queries: 4 (0.0040s) ][ live ][ 339 ][ ThingOne ]
