Hi gang. I know that for vintage vespa clutches, there is a tool to help hold the clutch as you tighten or loosen the nut (it's a curved, metal hook shaped tool). I was wondering any of you have used any other tools that work and can be found easily in hardware stores or online? I had seen some rubber strap-style wrench's...might that work? Also something that can be used with engine already installed on the bike.
Fab
