2020 supertech
2020 supertech
What could possibly go wrong with my abs unit for my 2020 supertech with only 6k miles on it? New part is at least $1,200. OUCH![/img]
Update found a used one from "across the pond" just installed it and ran new brake fluid through it. all seems ok .
On screen..... ABS Disconnected
Service
I get that because I unplugged the harness and plugged it back in but i'm guessing a service tech has to reset that?
⚠️ Last edited by Miner1 on UTC; edited 1 time
2019 GTS 300 HPE Supertech E3 64,000km
what could go wrong? well removing it would cause a problem ROFL emoticon
2020 supertech
2020 supertech
Well it was diagnosed as having failed. So with parts and labor a 2k bill. I took it out and am looking for a used one
I thought it would be cheaper in Europe, but MSRP for 1C002747 is 1006 euros. Best price I can find for it new is 825 euros. Do they go out a lot? If they do, I'll add it to the site. Considering they've been using this part number for 10 years, I would think it should be cheaper.
The new part appears to be 1C006399, and MSRP is about 800 euros. I don't know if they're interchangeable, but maybe someone does. According to one site, it fits the 2022 GTS (NAFTA), and the previous one is listed as fitting the 2022 GTS (APAC).
Is this the part that was replaced when they did the recall on the GTS ABS brake system?
Here's what they use 1C002747 on, if that helps you find one.
BEVERLY 300 - 400 / GTS 125 - 300
1B0008830000C Paraspruzzi
posteriore
VESPA - Vespa GTS 125
Vespa GTS 125/GTS Super 125 4T ie
ABS E4 2016 - 2018 (EMEA)
Vespa Super GTS 125 4T 4V iGet ABS
E3 2017-2020 (APAC)
Vespa Super GTS 125 4T ie
ABS-NOABS E3 2009-2016 (EMEA)
VESPA - Vespa GTS 150
Vespa GTS 150 / GTS 150 Super 4T
3V ie ABS E4 2016 - 2018 (EMEA)
Vespa GTS Super- Super Sport 150
4T 3V ie ABS E3-E4 2017-2021 (APAC)
VESPA - Vespa GTS 250
Vespa GTS 250 4T 4V ie NOABS E3
2005-2016 (EMEA, APAC)
VESPA - Vespa GTS 300
Vespa GTS 300 GTS 300 Super 4T 4V
ie ABS E4 2016-2018 (EMEA)
Vespa GTS 300 4T 4V ie ABS E3
2014-2016 (APAC)
Vespa GTS 300 4T 4V ie ABS E3-E4
2014-2018 (NAFTA)
Vespa GTS 300 4T 4V ie ABS-NOABS
E3 2012 - 2016 (EMEA, APAC)
Vespa GTS 300 ie ABS E4 2017
(APAC)
Vespa GTS 300 Super - Tech ie ABS
E4 2017-2022 (APAC)
Vespa Super GTS 300 4T 4V ie ABS
E3 2014-2016 (APAC)
E3 2017-2018 (APAC)
E3- E4 2014-2018 (NAFTA)
ABS-NOABS E3 2008-2016 (EMEA, APAC)
VESPA - Vespa GTV 300
Vespa GTV 300 4T 4V ie NOABS E3
2009-2010 - Touring 2010-2016
(NAFTA, APAC)
Vespa GTV 300 SEI GIORNI ie E4 ABS
2017 (EMEA)
2017 (NAFTA)
2017-2018 (APAC)
the recall a few years ago was for the brake lines. the abs unit was not supposed to be replaced.
@n2tattoos avatar
2016 GTS 300ie
@n2tattoos avatar
2016 GTS 300ie
Also, the ABS UNIT requires dealer programming by an authorized Piaggio dealer. Requires P.A.D.S. software.
Or an odb scanner that has piaggio/vespa functionality. ie not a cheap generic scanner. My OBDStar 'Piaggio Group/Multi' edition does support this function. https://www.obdstar.com/Products_280.html (US$399)
⚠️ Last edited by SteelBytes on UTC; edited 2 times
@n2tattoos avatar
2016 GTS 300ie
@n2tattoos avatar
2016 GTS 300ie
SteelBytes wrote:
Or an odb scanner that has piaggio/vespa functionality. ie not a cheap generic scanner. My OBDStar 'Piaggio Group/Multi' edition (US$399) does support this function. https://www.obdstar.com/Products_280.html
No, the software is only for dealer use.
buy and try before you judge.
or even just read the details in their linked document which gives detailed function list for each bike model. (weirdly it's an excel spreadsheet)
it also does other things like 'virginise' the ecu, reset adaptive params, control the abs pumps for bleeding, enable/disable asr, direct control of relays for fan, headlight etc, change the odo on the supertech dashboard, and many more specialised piaggio things.
it's these abilities that distinguishes it from their basic cheaper models.
attached ABS "special function" menu (also has non-special abs functions like read front/rear sensors, model/firmware, etc).
Bonus trivia:
The VIN is stored in the ABS unit.
I have replaced the ecu and using my obdstar i go into the ecu menu and it shows no vin as expected. I then go into the abs menu and it shows the correct vin.
[ Time: 0.0134s ][ Queries: 4 (0.0023s) ][ live ][ 318 ][ ThingOne ]
